Modifying gcode on export?
Go to solution Solved by GregValiant,
Posted · Modifying gcode on export?
Hi, still relatively new to using Cura for only about a year. I noticed that whenever I create a gcode file to print on my Ender 3, it is written so the bed heats up first, waits until it is up to temp, then starts heating the extruder. I believe I can make small savings in print time by modifying it to preheat both at the same time. I have written out the gcode that Cura spits out below.
M140 S62
M105
M190 S62
M104 S210
M105
M109 S210
I rearranged this code to be:
M140 S62
M104 S210
M105
M104 S210
M109 S210
This seemed to work in preheating both at once. Is there a capability in Cura to change this on all gcode files that Cura generates? I looked in the printer settings and it seems the custom start gcode appears after this code snippet. I have attached an example gcode file to this post. My cura version is 5.2.1. I would greatly appreciate any help anyone can provide. Thanks!
CE3E3V2 Feeder Adapter v17 .gcode
    • Solution
    Posted (edited) · Modifying gcode on export?
    Go to "Manage Printers" and "Machine Settings".  You want to edit the "StartUp G-Code".
    Cura will always put the heating commands in if there are no "replacement patterns" in the startup.
    This is based on the Ender 3 Startup Gcode.  My changes are in bold.
    ; Ender 3 Custom Start G-code
    G92 E0 ; Reset Extruder
    M220 S100 ; Reset the feed rate
    M221 S100 ; Reset the flow rate
    M140 S{material_bed_temperature_layer_0} ; Start heating the bed
    M104 S{material_print_temperature_layer_0} ; Start heating the nozzle
    G28 ; Home all axes
    G0 F600 Z5 ; Move up to ooze
    M190 S{material_bed_temperature_layer_0} ; Wait for the bed
    M109 S{material_print_temperature_layer_0} ; Wait for the nozzle
    G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish"
    ;End of StartUp
    The "reset" lines are in case you happened to tune a previous print from the LCD.  They set the printer back to the default 100% feed and flow rates.
    Edited by GregValiant
    On my E3V3SE I find when I do that I have the extruder idling for a while waiting for the bed to finish heating, and the bed heating is a roadblock in my startup code since I like to home when it's hot (it's a PC metal bed, so it will technically be slightly larger when heated, but this is one of my many cases of "it works in theory, so I'm doing it" rather than the "in practice, it won't make a damn difference" line of thinking).
    My bed seems to take interminately long to heat up (it's probably average), but if I only start heating the extruder once the bed is hot, then I'm waiting for that after it homes and moves into drooling position it takes a while for the extruder to finish heating, so I did this:
    M190 S{material_bed_temperature_layer_0 - 15} ; Start heating the bed
    M104 S{material_print_temperature_layer_0} ; Get the extruder going
    M190 S{material_bed_temperature_layer_0} ; Finish heating the bed
    G28 ;Home
    The StartUp Gcode is very machine dependent.  I used to have separate printers for PLA, PETG and TPU because I wanted different StartUp's depending on the material and speeds.  With the StartUp now able to handle logic I'm taking advantage.
    This makes adjustments to the StartUp per the current Cura settings.  That makes it ambidextrous and I now only have one printer defined.
    ;--------------------------StartUp Gcode
    G21 ; Metric Units
    G90 ; Absolute Movement
    M82 ; Absolute Extrusion
    M220 S100 ; Reset FeedRate
    M221 S100 ; Reset FlowRate
    {'M104 S175 ; Standby while bed heats' if material_bed_temperature_layer_0 > 65 else ';M104 ; No standby'}
    {'M190 S' if material_bed_temperature_layer_0 > 65 else 'M140 S'}{material_bed_temperature_layer_0} ; Bed wait if over 65
    M109 S{material_print_temperature_layer_0} ; Hot End Temperature
    G92 E0 ; Reset E
    G28 X Y ; Home XY axes
    G1 F2700 Z10.0 ; Move Z
    G0 F{speed_travel*60} X1.0 Y20 Z0.3 ; Move
    G1 F{speed_print*60*2/3} X1.0 Y200.0 E15 ; First purge line
    G0 F{speed_travel*60} X3.0 Y200.0 ; Move
    G1 F{speed_print*60*2/3} X3.0 Y20 E30 ; Second purge line
    {";G1 F" if "TPU" in material_type else "G1 F"}{retraction_retract_speed*60} E28 ; Retract if not TPU
    G1 F2700 Z12.0 ; Move Z Axis up
    G4 S1 ; Wait for booger to solidify
    G0 F{speed_travel*60} X3.0 Y35 Z.35 ; Move over
    G0 F{speed_travel*60} X3 Y50 Z0.35 ; Wipe
    ;--------------------------End of StartUp
          • Heart
        • 7 replies
