Posted · File will not print - solved.
I tried doing my first print today. So I loaded a model into Cura and wrote the Gcode with standard settings.
But when loading the file into the Ultimaker 2 it says: 'This file will override machine setting with setting from the slices'. If I confirm, nothing else happens. It dosnt' warm up or print.
Gcode in the beginning looks like this:
;FLAVOR:UltiGCode
;TIME:9758
;MATERIAL:13280
;MATERIAL2:0
;Layer count: 79
;LAYER:0
M107
G0 F9000 X61.51 Y75.91 Z0.30
G0 X61.51 Y75.91
;TYPE:SKIRT
G11
G1 F1200 X62.06 Y78.89 E0.36405
G1 X62.06 Y78.89 E0.36417
G1 X62.16 Y79.44 E0.43129
G1 X62.50 Y80.06 E0.51583
G1 X62.57 Y80.20 E0.53553
G1 X62.97 Y80.93 E0.63462
What did I do wrong?
Regards,
Kris
    Kris -
    Welcome, and I'm sorry you're having problems. On the face of it, I don't see anything that you're doing wrong. But, are you sure that's the same file? That's standard UltiGcode, which should print just fine on the UM2, and not generate the warning about 'overriding settings'. That makes me think that that isn't the file that you are trying to print.
    Can you copy the file back off the SD card, and double check that that is what it looks like? When you copied the file to the SD card, did you eject it properly from the computer, to make sure the file had finished writing fully?
    What version of Cura, and OS are you using?
    Many thanks for the quick reply. You saved my day! The file apparently got corrupted when saving.
    Used another SD- card reader and voila...it works.
    Again, thanks alot!
    Kris
          • Heart
        • 4 replies
