Could it also be that the nozzle diameter has an impact on the result of the print?
I made the observation when using a nozzle with 0.6mm diam.
Can the line width be less then than nozzle diameter?
Otherwise, I appreciated your comment about this subject.
Thanks.
Slashee_the_Cow 620
Remember that the diameter will always be a multiple of your line width ± minimum wall line width, but it's best to not rely on the minimum line width and make it a multiple of your line width to keep flow consistent.
There's also the setting Experimental > Slicing Tolerance which controls how it rounds numbers when they don't match:
