By the way - an extreme hack fix would be to stretch the robot vertically by 2X in cura "scale" feature, print with .4mm layers and set flow to 50%. LOL!
What about:
M92 Z200*16/3
I would try it if I would not have destroyed some stepper drivers recently... B)
@Brendan: Please, just follow gr5's first advice...
Haha, I'll stick to fixing the jumper position for now. If I feel like putting my printer to the test I'll try the other ideas.
You were spot on gr5. It took a second to fix, and I can already see that it's printing properly. Absolute legend!
Thanks guys.
gr5 1,968
Easy fix! This is usually caused by the Z stepper jumper being wrong. I even still have a picture in my gallery of it
Click on the image above and look at the red circled part carefully. You want yours like that. The right most jumper should be either removed or placed as shown in the picture so that it does nothing (connects the pin to thin air). I suspect your right most connector is in place like the 2 next to it.
