Posted · Color Scheme "Fix"
Hello... i'm using Cura V. 5.4.0
The question that i have is i want to enable "multiple" color scheme options on Cura.
My meaning is in my Cura only shows Color Scheme: Line Type
Doesn't show other options as: Material color, Speed and others..
Is there any option to enable this???
    Your Cura is running in "Compatibility Mode" so other options aren't available.  Whether it's in that mode because of an issue with your OpenGL version (on your video system), or because it is set that way in "Preferences / General" and the setting "Force Layer View Compatibility Mode" you will have to check.  If the OpenGL driver is less than version 4.1 (I think) then you can't get out of compatibility mode.
          • Heart
        • 4 replies
