Sending print job stalls sometimes
Go to solution Solved by Slashee_the_Cow,
Posted · Sending print job stalls sometimes
Only sometimes:
When pressing "Print via cloud" a dialog box appears with "Sending Print Job / Uploading print job to printer" and a progress bar, but the sending never starts.
In a previous version of Cura this dialog box could be closed with an x in the upper right corner, and then I could try again.
Now I have to close Cura and start it again to try again. This is less than optimal.
It only happens sometimes. I haven't seen any system in when it happens. There is no error message, it just seems to wait for something that never happens => wait forever.
Please re-enable the close option on the dialog box, alternatively fix the issue 🙂
    • Solution
    You can submit a bug report about the failure to send but unfortunately if you can't recreate it reliably there's only so much they can do. You should include the part about the close button in the dialog box, that part they may be able to help with - it's possible it wasn't removed intentionally, but when Cura moved to a different version of its UI toolkit, for example.
          • Heart
        • 4 replies
