21 hours ago, Slashee_the_Cow said:I'm pretty sure that description makes sense. Unfortunately (unless you have one, since you don't say what you have) you can only do it a dual extruder printer (well technically you could do it with a fair amount of gcode editing and then manually changing the colour MANY times, far more hassle than sticking them together manually).
It might be possible if your indent is only a couple of layers thick (basically how far the nozzle extends out of the print head) but "a couple of layers" generally isn't enough to completely obscure the colour below and it still wouldn't adhere nearly as well as if it was done on a dual extruder printer.
When it comes to colour changes on a single extruder printer, the only way to go is up: you pause at a layer change and swap the filament, then the layers above will be a different colour, but you generally need 3-4 layers to completely obscure the colour below (lighter colours - and white especially - need more).
You can do some pretty cool stuff if you have as much free time as me though:
And if you have to resort to manual attachment, one important thing: if you're using PLA, then cyanoacrylate (plain old superglue) works INCREDIBLY well.
Thanks for this and love the print!
This is pretty much as I suspected. I'm using PETG and adding two layers of red on to a white base but I can only see how to print the whole layer in red, or as you say make many filament changes in one print. Seems a shame that I can't just add a bunch of models and then squirt filler into the gaps! You confirmed what I thought, thanks for replying :)
Slashee_the_Cow 443
