Thanks for the reply and shifting the thread ,
Printing off an SDcard , my original CR10 runs off a pi but not the enders.
Yup same gcode.
Standard filament holders.
yep works fine for a certain time then the damn thing messes about so I could use that printer for small objects but that seems a bit of a waste.
thing is it was working fine when I bought the 2 printers at the same time but now this one is just annoying me.
Im giving it another shot now and we are a couple of hours in , working fine .
Edited by PaulGri
Slashee_the_Cow 481
Hiya! Your friendly assistant mod Slashee here.
This isn't really about improving prints so I'm moving it to "third party products" forum.
I guess my first questions would be:
You could try swapping the motherboards between the two to see if the motherboard is the problem but sometimes Creality have used different boards for the same model printer just so they can get enough, so if they're different I don't know whether swapping them would work.
If it just suddenly stopped working I doubt it's the firmware but anything's possible. You could try reflashing it but with Creality printers that's really somewhat of a flip of a three sided coin whether it'll make it better, not change anything, or worse.
About the stepper motors: are you noticing any performance degradation or loss of accuracy as the print goes longer? I mean, even if that's happening it could be a long shot, but any difference in behaviour between the two is worth bearing in mind.
