The white bits indicate points where it starts extruding after a move - in this case that's the Z seam, where it starts printing each layer. It'll do a white dot for anywhere it starts extruding on outer walls because where it starts can be visible sometimes.
Playing around with the Z seam options in your print settings (often the easiest way to find which options hide the Z seam best) if I set Z Seam Alignment to Shortest and Seam Corner Preference to Hide Seam puts it away in this corner:
Slashee_the_Cow 621
If you could provide a Cura project file of your print (.3mf, in Cura go to File > Save Project) that would help a lot more than just having the model because it'll contain all your print settings.
Your problem here is that the wall sections are tiny. They're a single wall thick. Assuming I'm getting the scaling right; the file doesn't use mm for units so I just resized it to fit my bed (best case scenario). Basically, the print head makes a quick stop then moves to the next one. There's no way to do that cleanly, even if you have the best retraction settings in the world (although it might not retract over that short a distance anyway.
Here it is step by step:
Notice how it's doing a tiny little hump at each section? That's as far as it can go out (and come back in) without going into an area so thin it would have to stop and move back into the centre, because Cura prints the outline as a single, uninterrupted line (where possible)
The bits which are more noticeable are probably the ends, not the starts, since they'll get pulled away from their position because they're not dry yet.
So how do we fix it? Go to Walls > Minimum Wall Line Width and set it to the lowest advisable setting, 60% of the nozzle diameter. 0.4mm nozzles are fairly common, that gives you a minimum width of 0.24mm (although whether that's enough depends on how big you're actually printing it):
Now instead of doing one thick wall where it can't go back, it does a thin wall out and then back in.
This still won't give you a perfect print: Especially if your printer has a Bowden extruder (you put the filament into a thing somewhere on the frame which has a tube leading to the print head). It'll hopefully be a lot better, but it'll be constantly changing the flow rate between what it takes for one fat wall (between the bits that go out) and thin walls (for the bits which go out) and there's no way the extruder is going to be able to keep up. It'll almost certainly lead to overextrusion or underextrusion (or a bit of both) in these sections.
Also FWIW, this isn't the problem but significant portions of your model don't have any surfaces with the normals facing outwards:
Some programs don't produce very good STL files, so it's probably not something you did. Blender has problems. SketchUp is notorious for producing files with these sorts of problems. But even CAD programs which should be able to produce the best output files possible still stuff up sometimes.
BSSArch 0
Thank you so much for your thorough response! It appears that adjusting the 'minimum wall line width' is going to be quite beneficial. I'll give this a try once the current print is finished.
While I acknowledge that the profiles are somewhat thin, we've successfully printed similar designs in the past, yielding results like the one with the 2 cents in the picture. We're using a bowden extruder (CR10S).
Upon investigation, I've discovered that the previous version of Cura (4.13) handled things differently. That version didn't feature the 'minimum wall line width' setting, and after slicing, there were no white dots on the walls, as shown in the attached screenshots.
Reducing the minimum wall line width eliminates most of these dots, with the exception of one, which i can't seem to get rid of.
I've attached the models in 3mf format for both 4.13 and 5.7.1. I fixed the STL 😉
I'll give this a try.
Cura 4.13.3mf Cura 5.7.1.3mf
