I want to print a hollow object on a 3D printer, but it produces a full inside
It's probably a problem with the model (most likely the normals) but I'd just go with Slashee's solution.
Have you tried to set the infill at 0% and make sure that walls have a minimum os 2 lines.
and set top and botton layers at 0, so you have no top or bottm
GregValiant 1,409
Look in the Mesh Fixes section and make sure "Remove all Holes" is disabled.
If it is, then there may be a problem with the model and it might need repair.
