5 hours ago, Slashee_the_Cow said:Also worth noting that as you get down to this small, the resolution (steps/mm of the motors) of your printer can come into play, especially on cheaper printers. I'm not saying your printer is cheap. I've never looked up its price 😄
It is a fairly low end printer. It's not exactly cheap, but that's mostly because of its size.
Thanks for the line size guidance, it seems like in the 3d printing world you can ask 5 people and get 7 different opinions on the right way to do something.
As for my flow rate, the profile I am using is based on the stock TPU settings for this printer. All the stock profiles have flow set to 90%, which seems like a strange way to do things, but it works on 0.4 nozzles for me. I have calibrate E-steps, but it has been a minute. I may need to do it again.
Acceleration is also part of the stock profile, but I was questioning that myself.
For the printer settings, where did you find those? I don't think I've ever seen those, and I definitely didn't set them to that. Thanks!
Slashee_the_Cow 429
Generally whenever you're going to test something (like using a tiny nozzle for the first time) it's better to do it with PLA since it's more forgiving and doesn't have problems other filaments do (like how PETG is stringy).
Now if I may do a Big Bulleted List™:
I'm pretty sure your printer can't print at 849,270 times the speed of sound (yes, ran the numbers, jokes have to be based in truth). You might want to have a look at that profile. And despite the pissing contest for "fastest acceleration" between printer manufacturers, I'm pretty sure yours can't go that fast. And it shouldn't. Not even the default acceleration, except maybe if you're running specialty high speed PLA.
Hope that helps you with your print and/or breaking some world speed records.
