Posted · Problème avec ma pièce 3d sur cura
Bonjour,
j'ai un souci lorsque je met ma pièce 3d sur cura, c'est comme si il manquait des couches
alors que la pièce et très bien sur fusion.
Merci d'avance pour l'aide
Xilit
    It's almost impossible to tell what's wrong without having the Cura project file (.3mf, in Cura get it set up then go to File > Save Project) or at the very least the model STL file. If you could post that it would really help.
    The model has errors in a stripe down the middle.  When the errors are surfaces facing inside out, or duplicate faces, or other problems - the slicer gets confused as to where the inside stops and the outside begins.  You end up with missing layers.  There are 1.33 million surfaces in this model.
    After repairing the file with Microsoft 3D Builder the slice looks as it should.
    • Heart 1
          • Heart
        • 7 replies
