Thanks, I found it, but in 5.7.1 it appears as a slash.
Cura injecting gcode mod (change filament) from previous projects.
Go to solution
Solved by Slashee_the_Cow,
Doh!, you are right. It was a hammer-and-wrench when I added the icon back in Cura 2.3 😉
1
ahoeben 2,025
See Extensions -> Post Processing -> Modify Gcode, or press the hammer0and-wrench icon next to the Slice button (which should show you a red badge indicating the number of active Post Processing scripts.
Slashee_the_Cow 541
To clarify the default behaviour, whenever you start a new project Cura automatically carries over the post-processing scripts from the last project you had loaded. You'll need to get to the post-processing scripts window (as @ahoeben described) to disable them for a new one.
Some people use many of the same post-processing scripts on all their projects so it's handy for them, but I agree it can be a bit confusing if you don't know to expect it.
MOESTEVENS 0
