Posted · After replacing Ultimaker main board the Z-axis goes too far.
Hello,
I replaced the main board of my ultimaker 2+ because it was broken.
When I turn it on, it starts initializing. The Z-axis moves all the way to the homing switch and moves up again but then it doesn't stop and crashes into the nozzle.
My gut feeling says it might be a jumper setting on the board somewhere since the board is compatible with all the Ultimaker 2 and 2+ printers, including the Extended versions.
Now, on the board I see something called EXT/IO. Might that be it?
By the way, the new board is the 2.1.4 version (the photo is the old board).
Does anyone know?
    • Solution
    if it raises up too far you likely have "extended" firmware installed which would send the bed up higher than expected on a non-extended.
    You need to reflash the firmware https://support.ultimaker.com/s/article/1667337917778
    Also no there is no jumper setting that controls this, its all firmware side.
    Thanks Dustin, that worked!
          • Heart
        • 4 replies
