Need help with the default home position in the Z axis
Posted · Need help with the default home position in the Z axis
I am using a davinci mini w+ (unfortunately) and the home position inside of cura sends it to the bottom of the gantry, im concerned it will crash into my prints upon completion as in the XYZ software the home position is at the top of the gantry. How can I manage the default home position (G28) or make it so it doesnt go to this position? Im pretty new to this and im sure the answer is out there I just couldnt understand it and google gave me the same irrelevant results no matter what I searched. please explain it like im 5
    Homing is carried out by a command in the StartUp Gcode.  Some printer definitions contain a homing command in the Ending Gcode as well.  Not a good idea.
    In Cura go to "Manage Printers", "Machine Settings".  In the lower right text box will be the Ending Gcode.
    The commands should lift the nozzle slightly from the print, then park the print head at the back (move the build plate forward) and shut down the heaters and XYE steppers.  The Z stepper is usually left engaged so the print head doesn't drift downward by itself.
    This is my Ending Gcode.  You can see there is no G28 but rather "relative" moves that get the print head up over the print, then parks it at "{machine_depth}" which Cura will replace with the number you have in your machine settings for the build plate size.  You can see that the only Z moves are upward so there isn't any chance of crashing the print.
    If you have a direct drive extruder you would want to touch up the retraction distances in this.
    G91 ; Relative positioning
    M83 ; Relative Extrusion
    G1 E-2 F2700 ; Retract a bit
    G1 E-2 Z0.2 F2400 ; Retract and raise Z
    G0 X5 Y5 F3000 ; Wipe out
    G0 Z10 ; Raise Z more
    G90 ; Absolute positioning
    M82 ; Absolute Extrusion
    M220 S100 ; Reset FeedRate
    M221 S100 ; Reset FlowRate
    G0 X0 Y{machine_depth} ; Present print
    M106 S0 ; Turn-off fan
    M104 S0 ; Turn-off hotend
    M140 S0 ; Turn-off bed
    M84 X Y E ; Disable all steppers but Z
    If you currently have a G28 in your Ending Gcode changing it to "G28 X Y" will keep it from homing the Z.
        • 1 reply
