You are of course right about the minimal discrepancy that no printer can currently display.
And you are also right that I just want to know. It has to come from somewhere; that kind of thing always bothers me...
The measurement is correctly given in the bottom left corner. So there is also a discrepancy in CURA itself...
I'll take a look at what I can set in FC regarding the resolution of export files; I'm still a beginner there also...
Slashee_the_Cow 621
What does the size indicator in the bottom left say? That should be the size of the imported file (although it might just round it up to 28 anyway).
It's also possible FreeCAD didn't export the STL as perfectly as expected (you have to know exactly where to look in the settings to control the output resolution of STLs, especially when it comes to angle increments) but the size is well within a reasonable margin of error.
And... I can understand why you're curious, but someone show me a printer capable of a 0.0087mm resolution and then I'll say this is something worth worrying about 🙂
