I'd just reprint that part in something tougher. Something slightly more flexible. Such as "tough PLA", ABS (many but not all abs filaments are a little more flexible than PLA making them much tougher) or Nylon.
The slight increase in flexibility means the part warps (just a tiny bit - maybe 0.2mm in your example) and this distributes the forces better and makes the part "stronger".
gr5 2,265
@fbrc8-erin - is there a buy-able part for that or do they have to buy the whole print head or what?
@oguzsah005 realize that many assemblies are not listed online. You can call your reseller and ask them what the smallest assembly is that includes what you want (include a photo). Although erin is an expert and can probably tell you what is the smallest part number and then once you know the part or assembly number you can order it from your reseller.
I have a friend who, I'm pretty sure, ordered just all the plastic parts alone of the print head and it was very inexpensive.
fbrc8-erin 302
The whole print head assembly is available; it's part 213194. That's the entire print head (plastic parts, cable, PCB, active leveling parts, fans, screws, nozzle seal), without the Print Cores. It should be orderable from your reseller, though as gr5 said, many resellers don't list some of the parts online.
I have the print head online and available, but unfortunately can only ship with the US.
It does look like there are 2 resellers in Turkey: https://ultimaker.com/resellers/turkey/
gr5 2,265
I think he wants to save money buy purchasing only the plastic parts or even just the one part he needs.
