Is there any way to overlap the seam when printing?
Posted
· Is there any way to overlap the seam when printing?
It sounds like the setting you're looking for is Walls > Outer Wall Wipe Distance - this will stop extruding at the seam but continue moving the nozzle past it. Usually it doesn't need to be very high at all (Cura will warn you if you set it above 0.8mm) but with a 1mm nozzle you might need to go a bit further.
Here comes Cura 5.9 and in this stable release we have lots of material and printer profiles for UltiMaker printers, including the newly released Sketch Sprint. Additionally, scarf seams have been introduced alongside even more print settings and improvements. Check out the rest of this article to find out the details on all of that and more
Slashee_the_Cow 541
