pointy end is fine.
Print looks great to me.
".4CC"?? You mean "CC 0.6"? It matters. make sure the line width is .6 if you are using a 0.6mm nozzle and 0.4 if you are using a 0.4 nozzle.
It could be that the filament sensor doesn't work well with this filament. If you don't see much underextrusion then turn off the sensor. I don't see much underextrusion but you might want to follow the advice of the manufacturer and set the flow to 105% (but no higher than 110% which can cause serious problems). And also turn off the filament sensor. It's in the menus on the printer itself.
Slashee_the_Cow 410
According to colorFabb's page on bronzefill:
So it's possible you have underextrusion, unless you already accounted for that 🙂
The infill actually looks worse than the rest of it to my eyes 👀
Infill lines should be as smooth as the rest of the print but that's the bumpiest infill I've seen in quite a while 😕
Probably not normal. Could have something to do with the metal inside the filament? Not sure. 🤔 Definitely cut off a bit below where filament goes back to normal before you try again.
What temperature were you printing at? colorFabb's page recommends 195-220, but with metal in it, I'd definitely be going towards the higher end of that - I'd start at 210° myself, and not be afraid to step up to 215 then 220 if I was still having problems.
Ultimately though it could just be a case of a printer not liking an exotic filament. Though I'd wait for @gr5 to have his say before you do anything because I don't know much about UM printers.
