Variable density infill?
Go to solution Solved by Slashee_the_Cow,
Posted · Variable density infill?
I've been having a lot of difficulty printing a couple of tall thin models, sections of a wind turbine blade, see my other recent thread for the project file, and having difficulty with getting top layers printing on top of infill when printing ASA.  I don't have the problem with PLA but with ASA inevitably there will be places where it doesn't go on smoothly and bits of filament warp/curl upwards, and then the extrude bumps into these and, given the tall thin piece, knock it off the build plate.  Having a largish model fail on the last few layers is pretty frustrating.  As you can see in the image the density of the infill was already pretty fine and the problem still occurred.
I've been able to get complete ASA prints using the lightning infill with 70% density and super slow bottom/top layers.  It's pretty great how fast a print can go without infill but for final prints I need some infill throughout to give it some stiffness.  I have a somewhat vague recollection that there used to be an option or something that caused the infill to get denser as it got closer to a top layer, is there such a thing?  I've tried a few things with support blockers and per model settings but haven't found a good solution.
Any guidance or ideas would be welcome!
    • Solution
    Your vague recollection is indeed correct! The setting you're looking for is Infill > Gradual Infill Steps
    Once you set a number of steps another setting will pop up asking for the height of each step - note that this goes from the top down, as you can see in my picture (example cube 100mm, steps set to 20mm, changes seen every 20mm from the top but the bottom 40mm is the same).
