I've did physically check on the cables and seems to be alright.
Is there a proper way to check if the cables are in good condition?
I did take apart the fan power connector from the main board when i was troubleshooting but i was carefully sure to put everything back where they belong.
I might have screw up my motherboard while i was touching it.
Do you have any linked where i can get a replacement motherboard for my UM2+
fbrc8-erin 311
It could be the main board, but it could also be an issue with the cable that runs between the fan and the main board--it's easy to damage the cables there. Have you checked those out?
Have you recently taken anything apart at the main board? Is it possible the orange and blue fan cable is not plugged into the right port? https://support.fbrc8.com/hc/en-us/articles/25226314830619-I-Installed-the-Extrusion-Upgrade-Kit-Now-My-Printer-Doesn-t-Work#“nofanconnector
