The height of the layers where the supports contact seems to be incorrect.
tabasco11
Go to solution Solved by Slashee_the_Cow,
Posted · The height of the layers where the supports contact seems to be incorrect.
Hello, I’m a beginner, so I’m working on creating and printing simple models. I have a question regarding this issue. When I slice the model and preview it, everything looks fine. However, when I output it to G-code and open it in Cura, some of the layer heights are incorrect as shown. I tried printing it, but due to this issue, the model split into two parts. What's wrong?
Screenshot2024-08-03at22_33_38.thumb.png.d85208ada385664ddfa778f62b76ca29.pngScreenshot2024-08-03at22_34_14.thumb.png.ed1a865e44c37c1e1dbb6ecef7b4051f.pngScreenshot2024-08-03at22_34_26.thumb.png.9f00435b64f4ddb570ff02b9e3262cb9.png
AdapterCase v2.stl AK2_adaptercase.gcode
    • Solution
    Hiya! It's easiest to tell if you can provide the Cura project file (.3mf, set it up then go to File > Save Project) as well as the model or gcode since that includes your printer and quality settings and such.
    However I'm going to hazard and guess and say... maybe Support > Support Interface Thickness isn't a multiple of your layer height?
    Or you might have Material > Support Interface Flow turned down?
    Without the project file, it's really hard to tell.
    • Heart 1
    Thank you so much for your support! 👀 The support interface is disabled, so it wasn't an issue with the support interface thickness. Instead, it seems that the problem was that the support Z distance wasn't a multiple of the layer height (it was 0.1mm versus a 0.3mm LH.)Screenshot2024-08-07at13_50_20.thumb.png.fd959b0409a0ba61b851dafe7e2a30fa.png
    However, the problem has likely been resolved. You saved me. Thank you very, very much. 🧠
