Can only put brim on one item on build plate with cura 5.8.0 is this a bug or am I doing it wrong?
Posted (edited) · Can only put brim on one item on build plate with cura 5.8.0 is this a bug or am I doing it wrong?
Edited by Slashee_the_Cow
fixed typo
    • Slashee_the_Cow changed the title to Can only put brim on one item on build plate with cura 5.8.0 is this a bug or am I doing it wrong?
    Posted · Can only put brim on one item on build plate with cura 5.8.0 is this a bug or am I doing it wrong?
    4 hours ago, Nomad6666 said:
    meant Brim
    Fixed it 😉
    Brim on multiple objects should work fine:
    If you could share a Cura project file (.3mf, get it set up then go to File > Save Project) we could have a look to see if there's anything amiss.
    yes it should and does for some files and not for other files very strange.. Guess I found a bugger in the matrix
    It could also be something to do with your models - if you can post a Cura project file of one that works and one that doesn't, our crack team of people with too much free time can get straight into trying to find the reason.
    I re-downloaded the file and the issue is fixed (funny that)
          • Heart
        • 7 replies
