Temps off
zrock
Posted · Temps off
I just upgraded to 5.8.0 with my Elegoo neptune 3pro.. when i save the file and put it in the printer im seeing my bed temp is 10 degrees above where it is set and teh nozzle temp is 20 degrees below what is set. When i check the file in Cura they are set at 220/60 but when i send it to the printer they are 200/70.. Im puzzled as i line 5.8 better than the 4.8 that came with the printer as it seems to show the supports much better as im battling a support issue with a project and they keep falling over before they get used and its not the print head hitting.
    Posted · Temps off
    If you ever used Elegoo Cura, it stores its configuration files in the same place as regular Cura but aren't always compatible. If that's the case, you should rename the Cura configuration folder (in Windows it's inside %APPDATA% or you can just go to Help > Show Configuration Folder and then go up a couple of levels) and rename the cura folder to cura.old or something. This will reset Cura from a blank slate, but you can copy your quality profiles over from the old folder (just know that if it suddenly stops working... that's probably why and delete them).
    If you could share the Cura project file (.3mf, get it set up in Cura then go to File > Save Project) and the output gcode you get when you slice it, we can have a look to see if there's anything that looks wrong.
