nozzle temperature at bed levelling
Posted (edited) · nozzle temperature at bed levelling
I am trying to keep nozzle temp down whilst bed levelling is happening. Ultimaker S5, with a carbon build plate - i'm trying to protect by having a cooler nozzle temp whilst levelling.
Has anyone done this, and can you share g - code?
thanks in advance
Edited by Suffolksails
    Posted · nozzle temperature at bed levelling
    You will need to specify what printer this would be for or no one will have a correct answer for you
    Ultimaker S5, with a carbon build plate - i'm trying to protect by having a cooler nozzle temp whilst levelling - would like it to be around 140 while levelling.
    3 minutes ago, Dustin said:
    this is controlled firmware side if I recall and cant (should not) be changed.
    i had a feeling that it was problematic!
    being semi novice on the gcode side what difference does griffin / marlin make?
    cura 5.8 has a start code, but one i found which i thinks starts bed levelling once bed is at temp seems to make nozzle temp rocket!
    this was the code.
    M140 S{material_bed_temperature} ;set bed temperature
    G28 ;home all axis
    M190 S{material_bed_temperature} ;wait for bed temperature
    M104 T0 S{material_print_temperature} ;set hotend temperature
    G29 ;auto bed leveling
    M109 T0 S{material_print_temperature} ;wait for hotend temperature
    Unfortunately, UltiMaker does not provide direct support via the Community.
    Please contact UltiMaker Support directly for help with this issue.
    here: https://support.ultimaker.com/s/contactsupport
    Thanks.
    Do you know if the preheat is set by the nozzle? the CC06 is being heated to 270 even when the initial (and) print temp of the nozzle is set to 240
