Cura 5.8 why no more standby Temp for filament change in Post Processing Scripts
Nomad6666
Posted · Cura 5.8 why no more standby Temp for filament change in Post Processing Scripts
This is a bummer as it makes changing out filament easy just take it out now I have to go through the big process of going and doing a ether the filament change or just heating up the tip what an extra step thats not needed please add Standby Temp back into Cura 5.8 Please and thank you...
    You might need to slow down for a minute there so we can get the details:
    • Exactly which script are you using?
    • What option/s are missing?
    • What are you doing as a workaround?
    Filament Change
    Standby Temperature  <- Missing
    Having to go out/back in ender 3 menu to heat up nozzle - Time consuming and not would not be necessary if standby temperature was still in the filament change script/I now have to set restart time so very long as it takes time to move through the menu and to wait for nozzle to heat up and then of course re&re Filament...
    I have other issues in this menu also but thats for the next post after the above is fixed..
    Your photo (second in the post) is from the "Pause at height" script which very much still contains the standby temperature setting:
    (And that script is often used for filament changes)
    The "Filament Change" post processor has never had a "Standby Temperature" as there is no parameter for it in M600.  You would need to use the "Gcode Before" option and add an M104 Sxxx line.  Since M600 turns everything over to the firmware - if the hot end is cooling off the firmware might be configured to act that way.
    Pause At Height has always had Standby Temperature and Cura 5.8 still has it (as Slashee shows in her screenshot).
    I set the standby in Pause At Height to 190 and it shows up in the Gcode just before the pause command where it always is.
