Cura Splits (ungroups) 3MF files
swagstaff
Posted · Cura Splits (ungroups) 3MF files
Hi there,
I have a problem with cura and 3mf files, when I add a 3mf file Cura splits it into component parts, this makes it impossible to print print-in-place files. However, when I import a STL file Cura displays it correctly, see attached examples.
STL import version
3mf import version:
It does this with all 3mf files, not just the example above, can anyone help?
