How to ignore an error? Unable to slice with current settings. The following setting have error: Wall transition length
Posted · How to ignore an error? Unable to slice with current settings. The following setting have error: Wall transition length
This is my slicing with 3 mm line width, but when I try to slice it with 5 mm I get this error Unable to slice with current settings. The following setting have error: Wall transition length.
Is there a way to ignore this error?
Or better do you know how to solve it?
    Posted (edited) · How to ignore an error? Unable to slice with current settings. The following setting have error: Wall transition length
    You could increase the "Minimum Thin Wall Line Width".
    The "Wall Transition Lenght" is - for some reason that I have not yet given enough thought about - limited to 3π * Minimum Thin Wall Line Width.
    Generally, you cannot "ignore" setting errors (marked in red), only setting warnings (marked in orange).
    Edited by ahoeben
