- Solution
GregValiant 1,342
You have "Hole Horizontal Expansion" set to 0.20 so you are getting that step.
Newer Cura versions have a secondary setting "...Max Diameter" that will allow you to turn that out. You can set it to 150mm and that step will go away but Hole Horizontal Expansion will affect the entire large hole and not start and stop at the cross hole.
Slashee_the_Cow 410
Okay so here we go:
The "missing line" problem:
There isn't a missing line. What looks like one in the preview is a display artefact generated by the shell lines narrowing at that point to accommodate the thinning of the model. Layer 200 vs 201 vs both of them:
The "missing seam" problem:
Your missing seams coincide exactly with the layers consisting of the hole:
So why no seam during the hole? It's actually pretty simple:
It can be printed in one continuous line (just follow the red line with your eyes) because it just turns around at the gaps the for the hole. When it's a complete loop it's forced to start and stop each line because the lines are separated. The inner walls will also have seams, but Cura doesn't show them because they're not going to be visible in the final product.
