GregValiant 1,342
The "Support Overhang Angle" in the project is only 15° as well. With that at a reasonable 55° support doesn't generate.
What this does need is the "Limit XY Accel and Jerk" post processor. It makes adjustments to the Acceleration and Jerk settings as the model gets taller. This model is tall with limited contact with the base. Violent "Y" movements can shake the print loose from the bed.
I'd go this way and make a gradual adjust in the "Y" Accel from 1000 to around 350 over a hundred layers or so.
Edited by GregValiant
Slashee_the_Cow 410
They're support. Easy to tell if you set Color scheme to "Line Type" 🙂
As for why they're printing there... Support > Support Horizontal Expansion. Set that to 0mm and boom:
Although do you even need support on at all? Thanks to the minimum X/Y distance those bits aren't even touching the model:
And other than maaaaaaaaybe that bottom front where it curves up nothing is overhanging at a particularly egregious angle - so I would just turn support off, start the print, and whistle to myself while I'm watching to make sure the first layers go down well. I would do that, if I could whistle. Since I can't I'd probably do the same thing except listen to the soundtrack for the Moulin Rouge musical instead of the whistling.
