Is the tank solid or is it just a wall around an open area? When you scale models down in size everything scales. If the tank is empty, then the walls may have dropped below what Cura can successfully slice given your settings.
As a test you can try turning on "Remove all Holes" and see if it will slice. If that works it will likely be full of infill though and that might not be what you want.
If that's the case you could try turning on Walls > Print Thin Walls and anything thinner than the minimum line width will be printed at the minimum line width.
Thank you for your answers. I increased the minimum wall thickness and my problem is solved.
GregValiant 1,342
Slashee_the_Cow 410
Mursel 0
