Thank you for responding.
It looks like Cura won't be of any help to me then. That's unfortunate, it seems to be a pretty robust program.
I'll dig deeper into FlashPrint then. I'm also wondering if a "printer neutral" program like Blender would be able to manage what I'm after.
Thanks again for your help.
Slashee_the_Cow 541
STL files don't have the geometry or settings of how they were sliced in them - they're just the overall shape of the model.
Here I've taken a cube and made it consist only of infill, then taken a sphere used it to make a cutout in the top of the cube:
I select the cube, go to File > Export Selection, save it as an STL, and load it in another program:
It's still just a cube. Even if I load it into Cura and slice it:
Just a cube. So the settings you pick in Cura don't actually do anything at all when you load an STL into FlashPrint 😞
So unfortunately you're limited to whatever you can change in FlashPrint.
And if you're curious, if I deselect the cube and just go File > Export (Export Selection is greyed out because I don't have anything selected) then I just get an STL file which contain the cube and the sphere merged into one object:
A Cura project .3mf file contains the settings, other slicers will import the models in it, but I don't know of any other slicers that will actually load the slicing settings from Cura.
gcode files don't contain models in them in any usable way. Just a long list of basic numerical instructions telling the printer where to move next and how much filament to extrude in that move.
There's a 99% chance it's nothing you did. If you set something to an invalid setting, it'll show up red in the list of settings and the error message will tell you that. Sometimes the Cura slicing engine just throws a bit of a tantrum and refuses to slice successfully. This can usually be fixed by changing a setting (any setting, really), slicing, then changing it back and slicing it again.
You can upload it if you put it into a .zip file (just that some people on the forum can be wary of zip files since people have tried posting ones with viruses, but most of the regulars don't worry because we're smart enough to know what to avoid).
