I manage a college makerspace that has 8 Ultimaker S5s with material stations. We originally printed PVA on all of them, but that became a nightmare to deal with. We now limit this to one printer to simplify things. PVA ALWAYS needs extra attention. If you don't use the spool CONSTANTLY, it will have problems. We fortunately burn through the stuff quickly because there are many students that want to create miniatures. Therefore our printer with PVA is running almost 24/7. We started buying the smaller spools of PVA to prevent it from going bad. We will only keep 2 spools in stock at any given time for the same reason.
In the 4 years that we have been using these printers, we only recently replaced all the belts. We have not replaced any other major parts except for a random failed bearing in one of the print heads. We replace print cores only when they have obvious problems. We are still using the original BB cores that came with the machines. Each printer has roughly 18,000 hours on it.
You can disable the flow sensor on the machine itself by the way. This will prevent it from stopping, but it will also ignore any under-extrusion problems.
Your problems are with the material itself, not necessarily the printer. All printers will have problems with PVA or another water soluble material. These materials are just terrible to print. They degrade rapidly.
I have not personally tried BVOH yet, but I may give it a shot to see if it does any better than PVA.
1
Dustin 178
Unfortunately, UltiMaker does not provide direct support via the Community.
Please contact UltiMaker Support directly for help with this issue.
here: https://support.ultimaker.com/s/contactsupport
