As it happens I am using Grid infill already, although it is interesting that when I used Lightning infill there wasn't any delamination. I'm still chewing on that.
I've actually got the model and side fans turned off and have the back (vent) fan at 10% to keep the ambient temperature around 41 deg.
Wrt small scale testing that's exactly what I did, although it still took me almost two reels of filament to figure out that even though the filament guide says 240-260 that it actually needs to be 270, and that even though I've never used glue for printing PLA or PETG, for ASA prints of any size glue is essential. I no longer have problems with small scale stuff but when I print a piece that takes most of the diagonal size of the printer I'm getting serious delamination on the front and back tip.
I realized this morning that I had the z-margin on the trailing edge, which is aesthetically the best but possibly contributing to delamination on that edge. Before I had that insight I created and started a print with an extension of the trailing edge out to a cylinder which should be less delamination-prone and is easy enough to remove post-printing. I printed off a partial height section of the blade with that and it seemed to work. In another 10-20 hours we'll know if it works for the full height piece. I printed the test at 275 deg on a 105 deg plate with reduced speed, and reduced the layer height to 0.16 from 0.2, so we'll see if that combination works for the full piece.
Slashee_the_Cow 410
I think Grid infill is supposed to be the strongest in the vertical direction, so you could try that. Also try increasing Infill > Infill Overlap to make sure the infill is sticking into the walls. Walls > Alternate Extra Wall also helps the walls grab onto the filament (since it'll sandwich it between lines) but obviously adds weight and filament use.
Also not that I've had problems with delamination, but I think I read somewhere that if you turn off (or at least turn down) the cooling that can help prevent it.
And don't forget Slashee's Silver Rule™: Small scale testing is your friend.
