Good Muuuhning 😉
Sorry to say but that don't work.
BPadhesion is set to skirt and Support-Brim active; there is nothing... I also can't change the (not existing) Brim size. What I only can do is to swap between calculated and not calculated (1.2 and 1). I'm not able to set a value by hand...
And now you...
Edited by CBX_Micha
Slashee_the_Cow 620
Set Build Plate Adhesion > Build Plate Adhesion Type to whatever you want that isn't Brim.
Enable Support > Enable Support Brim and set the size as desired.
