Bottom walls offset and infill offset Need help
BL4KM4K3R
Posted · Bottom walls offset and infill offset Need help
For some reason my bottom layers parts are getting offset. I can't seem to find the reason this is happening. I have tried on several different slicers and also different stls it all seems to do the same thing.  I have uploaded a picture. Please help me with some advice.
    Your Friendly Assistant Moderator Slashee says: this isn't really anything to do with Cura if you've tried multiple slicers so I'm moving this to the "Improve your 3D prints" board.
    Your regular Slashee says that if the problem is not the slicing (since you've tried multiple slicers and multiple files) it's either the printer or something to do with the printing process. Looks like it could be a problem with bed adhesion (or lack thereof). Without knowing what printer you have I have no idea what sort of bed you have but for a lot of things like glass you may need to apply some hairspray or glue to the bed before you print (just make sure to clean your bed properly afterwards with some isopropyl alcohol). People who aren't me may be able to give you better advice in that regard (I have an Ender-3 V3 SE which comes with a PEI plate and don't really have any adhesion problems to be fixed).
