Sorry for the late response. I have since found this to be a hardware problem. Thanks for the assistance though!!
Should anyone ever have a similar problem, the print head wasn't returning exactly to home after a print. I am also assuming there was probably a whole routine of things it wasn't doing because once I fixed that, all the other problems went away as well. It was able to mask itself as a slicer problem because of how I was troubleshooting the problem. Every time the print failed, I was -without even thinking about it- resetting the printer while messing with Cura. A classic case of “don't change two variables at once when troubleshooting”.
1
Slashee_the_Cow 619
To properly reset things in Cura (completely back to stock, like you have to set up your printer again and everything) you need to delete its configuration folder. In Windows it's %APPDATA%\cura
It would really help us to diagnose the problem if you could post these:
