On 9/13/2024 at 2:51 AM, Slashee_the_Cow said:I think you gotta stick to regular filaments 😄
Looking at the last picture, it's possible that the support is close enough that it's not doing a retraction when it moves from the support to the model. You can try changing Travel > Retraction Minimum Travel to something really low (like 0.1mm) to try and make it retract all of those bits.
Hi Slashee
I finaly die the test (had to print some other filaments first)
I reprinted the statue, so incan compare
Like you said, i set the 'retraction minimum travel' tot 0.1
It's a lot beter! (Like 70% tone)
But there are still zits/blobs on the surface.
(Photo's)
Now i printed a smaller one, and it looks like there are some more blobs. You van also see the stringing netwerk support and statue surface.
What can i do to improve this?
Slashee_the_Cow 438
Xhoax 4
Thanks for reply
Sticking to regular filaments is a no go 😁
This is a hot seller.
I was thinking in the same direction, i tried retract at layer change, but no difference.
Next time i will try to decrease the distance, i keep you posted
