- Solution
The problem lines aren't in the Cura output, so they must be being added by F-NIS.
It might be a bit of a hassle, but you just need to go into the gcode files after they've been processed and remove a single line. Right near the top (this is from the gyroid cube processed gcode):
;LAYER_COUNT:33
;LAYER:0
M107
G0 X103.20 Y63.95 Z0.30 F3600
;TYPE:SKIRT
M126 F
G1 Z19.90 F3000
G1 X103.40 Y63.65
G1 X103.40 Y63.65 F450
G1 X103.80 Y63.29
G1 X104.02 Y63.16
G1 X104.49 Y62.96
G1 X104.81 Y62.90
G1 X125.00 Y62.90
That G1 line with a Z coordinate - delete that line and save the file. Same for the grid processed file:
;LAYER_COUNT:50
;LAYER:0
M107
G0 X99.29 Y65.04 Z0.28 F3000
;TYPE:SKIRT
M126 F
G1 Z24.98 F3000
G1 X100.41 Y63.46
G1 X100.41 Y63.46 F300
G1 X101.76 Y61.94
G1 X103.22 Y60.61
G1 X104.67 Y59.54
G1 X106.53 Y58.45
So the result (for the grid) would be this:
;LAYER_COUNT:50
;LAYER:0
M107
;TYPE:SKIRT
M126 F
G1 X100.41 Y63.46
G1 X101.76 Y61.94
G1 X103.22 Y60.61
G1 X104.67 Y59.54
G1 X106.53 Y58.45
G1 X108.25 Y57.67
G1 X110.17 Y57.04
1
Slashee_the_Cow 541
Could you provide an example of one (or both) of those gcode files straight out of Cura, before processing it through F-NIS? The problem is right at the start of the first layer (from the "grid" file):
It moves to what would be a normal starting position, then opens a valve (at least that's what M126 is for usually, how your printer controls extrusion? Because none of the movement commands include extruder position) and immediately moves to 24.98mm from the build plate and tries to print the first layer. It corrects that at the end of the layer where it positions itself to start the next layer:
The "gyroid cube" file does the same thing except it only moves up to Z19.9mm
mohsengh 0
Hi Slashee_the_Cow,
Many thanks for your explanations.
I attached the generated G-codes without post processing.
I would be so grateful if you could tell me how can I fix the problem?
Once again thanks.
Grid-25%-CYL1-33mmD-15H.gcode Gyroid-20%-cube 2by1cm.gcode
