That was after I disabled and cleared the log.
I removed the software, deleted the settings folder /.local/share/cura, reinstalled it was still an issue.
I then wiped my Linux partition and reinstalled Linux Mint 22, my /home was on separate partition and keep my data.and reinstalled cura and now it works. I also setup TimeShift this time in case I need to roll back.
Slashee_the_Cow 621
Your log file shows the USB printing plugin causing several errors during the slicing process and making Cura kill the CuraEngine process.
I gather from your other post that you tried disabling the USB printing plugin. Is this log file from before or after that? If it's from before, please delete the log file, load Cura, try and slice a couple of things to generate errors, then post that.
If it's from after you disabled the USB printing plugin (and restarted Cura, since it can't load/unload plugins on the fly) and the USB printing plugin is still causing problems, then... we need to try and figure out why it's still loading and causing problems 🙂
