Yes, as I said, you can create a custom material, and it IS synced with the printer (at least the S5).
But you lose access to the default profiles.
There is no reason for doing so: it should be possible to take an existing generic materialtype (like generic ABS), duplicate it and tweak it as generic ASA. However, Cura is not syncing it with my S5. It's not that the S5 is not accepting it, it is Cura not exporting it: I cheated by asking a sync through USB and dumped the file: no trace of my "generic ASA" based on "generic ABS".
Maybe I oversimplify, but those default profiles, when used by a certain materialtype, are just overwritten by some materialtype parameters. When you create your custom profile, you just do the same, but manually.
Slashee_the_Cow 619
Cura shows a generic ASA for me (running 5.8.1) although I'm not using an UltiMaker printer so it's not syncing materials with the printer or anything.
Quality profiles are tied to printer definition, material type and nozzle diameter (at the very least). For example, my Ender-3 V3 SE definition is based on the creality_base definition which only comes with quality profiles for PLA, PETG, TPU and ABS:
So if I select something which isn't one of those it doesn't like me or give me any default profiles to work with:
So I'd need to make my own.
But if you're using an UltiMaker printer (and not my cheap Chinese crap) and you're having troubles syncing profiles with the printer you should probably contact UltiMaker support as official support is not offered through the forums.
