Add the Calibration Shapes plug-in from the 5axes github page to Cura 5.5 ?
bchhabra
Posted · Add the Calibration Shapes plug-in from the 5axes github page to Cura 5.5 ?
How do I add the Calibration Shapes plug-in from the 5axes github page in Cura 5.5 ?  It's not in the Ultimaker Marketplace and it has some calibration models I would like to use... I need to know the folder and path in Windows 11 to download and unzip the github down.load
    If there's a .curapackage file you can download, then you can just drag and drop that onto Cura's window and it will install it.
    Otherwise, in Cura, go to Help > Show Configuration Folder then go to the plugins folder inside there. Each plugin has its own folder so if a zip file doesn't have all the files grouped inside a folder, you need to create one for the plugin and extract it in there, or just extract it straight into the plugins folder if the zip file already has a folder structure.
