Posted · PVA support burning and deforming
Does not looks wet to me, even if PVA will "always" be too wet to be printed with, haha.
It's normal business, don't use PVA. It's not (only) a rant, it's a real honest and direct advice that might avoid use hours and hours of pain : don't work with it. Use some other soluble alternative (Polydissolve S1 or BVOH), and even theses, try to avoid as much as you can. Consider your printcore jammed and clogged after each uses of theses material if you don't use it continually.
