Sorry, I was confused, I thought that "save to disk" at the bottom right after slicing was saving the project.
Anyway, the picture you are showing, doesn't resemble the preview!
Disable Special Modes > Arc Welder.
UltiMaker printers don't need it anyway because their motion planners look several moves ahead and can figure out a curve by themselves. I have no idea why it would mess up the slice that but when I disabled that and sliced it again and loaded the ufp file for the gcode preview, it looked fine (unlike the donut from hell pictured above).
Thank you.
I learned that "preview" is not necessarily what is sent to the printer, but add-ons might "improve" the slicing result...
and how you can check what is sent to the printer.
I was probably too fast and too optimistic.
I printed it again, after uninstalling the add-on and after verifying that the ufp didn't show any stray filaments.
This is the result (i made a picture of the other side):
A lot of filaments in the wild, at two places: the top and the bottom of the support, nowhere else.
Hi @RolandDM,
I've tried to open your "project" file, but there was just a 3MF file without your printer settings.
Try to save the settings when you have sliced the object, -in order to have the needed data saved into the 3MF file.
By the way, what kind of filament material are used in "between" here?
Hmm, when I uploaded the second 3MF file I've got the project file..
Thanks
Torgeir
Edited by Torgeir
Hi @RolandDM.
I've been looking at your, settings using ASA and PLA as support. As there is no configuration files for ASA, -and PLA are a little far from ASA print temperature (that's around 245 deg C). ..
The PLA seems not to stick well to ASA filament (brands used).
I'll think it will be better to use tree support (attached in the center of the object at bed) and using ASA for support as well.
Good Luck
Torgeir
Slashee_the_Cow 541
Howdy!
If you could provide the Cura project file that would help (your 3mf only contains the model). Get it set up then go to File > Save Project (some people get this mixed up with Export) since a project file will include your printer and print settings.
Looking at the gcode from the UFP file it looks like it's meant to print about as messed up as your end result is:
That's actually pretty impressive, I couldn't get it that messed up if I tried 😄 But also why the project file is important so we can try and figure out how it gets like that.
