Unfortunately, UltiMaker does not provide direct support via the Community.
Please contact UltiMaker Support directly for help with this issue.
1 hour ago, Dustin said:Unfortunately, UltiMaker does not provide direct support via the Community.
Really.. seems like they used to once upon a time... anyway....
I went back to PLA and it behaved normally. Once this print is done I'll retry the ASA and see what happens. It was weird to watch the temp chart just getting started to heat and have the printer kick off doing the purge.... when I went back to PLA it waited until the temp was up...
ok, I printed ASA today, it went OK. The core temp increased as soon as the job started but didnt really get to full temp before the purge started. Still, it made it ok.
This time the job started with the cores empty. It kinda look like when I had the trouble before the core had previously used the same material and so it didnt need the time it took to load material from the station.. hmmm.....
JTMD 21
I have to wonder: are the commands that get the printer ready to print (like purging) generated in Cura? or are those steps in the firmware for the machine?
