http://www.thingiverse.com/thing:19031 - 15x15x20.5cm
Came out looking very nice, unfortunately not waterproof due to some extrusion issues (and the bottom is pretty leaky)
I printed the 0.7 scaled:
Leaking at the bottom somehow, and underextrusion at some point, probably due to spool friction
Printed a few holders for the quick-change tool holders on my CNC mill that resides at Stockholm Makerspace.
Material is Colorfabb Dutch Orange PLA, the color is a perfect match
I couldn't be more pleased with my new Ultimaker 2!
Here's a screenshot of the supports generated in MeshMixer:
Sorry to crash the party but I see some (very faint) underextrusion. Also there is some banding. Did you by chance print with Faberdashery white and which settings did you use?
I am asking because I have a somewhat similar issue.
Nice printed skull!
Maybe you could share the Model-file?
Hmm. I've used a few different 3D printers over the past couple of years. This skull ranks up there with one of the best prints I've gotten from an FDM printer, and I'm quite picky (I'm a professional illustrator/graphic artist, planning to use my Ultimaker 2 for sculpture work, among other things). The skull is only about 2.5 inches in height. I had to use a macro lens to take the photo on my DSLR, then I reduced the image in Photoshop which sharpened it. The coin in the background is a US quarter.
Here are the settings I used (if you click on the photo I posted, you'll see more info):
0.1 layer height
0.8 shell thickness
Retraction enabled
0.8 Bottom/Top thickness
20% Fill Density
30 mm/s Print speed
Colorfabb Standard White filament
Print time: 10 hours
0.1 layer height
0.8 shell thickness
Retraction enabled
20% Fill Density
30 mm/s Print speed
Oops… Forgot to add:
Nozzle temp: 220
Bed temp: 60
Retract length: 5.5mm
Retract speed: 35mm/s
I also find that enabling combing gives me fewer surface blemishes.
Nice printed skull!
http://www.thingiverse.com/thing:43591/#files
I downloaded the skull_Fill_Build_Space.stl file which is the entire skull as a single piece. The model had some visible faceting on its surface (especially the top of the skull) due to the relatively low polygon count for such a detailed model, so I brought it into Blender and applied a subdivision surface modifier set to 1 subdivision level before I exported it and brought it into MeshMixer to generate supports.
hi guys.
can i ask. has anyone designed a iphone holder that can clip onto the bottom of a steering wheel.
I have a really good new app for speed cameras but I want the screen to be pinned onto my steering wheel so I can see what little nasties are coming up.
I had a quick look around and couldn't find anything.. anyone have this before I start up solidworks ??
Thanks.
Gruss Gott aus Bayern
Ian :-)
Finally got around to painting my coca cola logo. I wanted to keep the colors simple to get that unmistakable coca cola feeling.
Watched Terminator 1 during the weekend, and what do you know, I felled compelled to print it. :grin: The http://www.thingiverse.com/thing:288467 is on Thingiverse. It was printed on Ultimaker Silver Metallic @ .1mm layers, 60mm/s, 230deg, 10% infill and with no support. I'm quite happy with the results since there's no visible print lines, I didn't do any cleanup and it looks pretty nice. Great material! Now printing one at the maximum build volume of the UM2, 30+ hours!
Ho wow thats pretty good!
Watched Terminator 1 during the weekend, and what do you know, I felled compelled to print it. :grin: The model is on Thingiverse. It was printed on Ultimaker Silver Metallic @ .1mm layers, 60mm/s, 230deg, 10% infill and with no support. I'm quite happy with the results since there's no visible print lines, I didn't do any cleanup and it looks pretty nice. Great material! Now printing one at the maximum build volume of the UM2, 30+ hours!
I love this material. I'm almost out already and need to find a replacement... Pretty nice print . Speed might have been your main issue. Still, pretty cool!
Did a set of eight 170mm wheels for an 88mm Flak. Material innofil black ABS, layer 0.25mm, no fans. Each wheel has a weight of around 200g (hollow). Part of the rim and the shafts are printed separately with 0.1mm.
Approx. 120h in total, plus 6h for one that failed because stupid me had to try out another glue stick.
At first I used ultimaker black ABS. Turns out the innofil materials prints allot better.
I printed this bad boy earlier this year at the request of the production designer.
Printed at various resolutions and speeds in about 25 pieces and total print time of 120hours+
rough wingspan was 550mm and it took a hell of a lot of paint and filler to get it to a stage to get it to be Nickel plated (most of it done by a talented friend)
Lucky bastard, having access to the original files like that. Some people would pay good money for that file I'm sure
Sadly i don't have them anymore either :(
Just a few, of my latest, printed objects...These are my first self painted models.
First try to print a picture. It's my wedding :mrgreen:
Looks with a bit of color even better
Hey guys, this is not my model, or my print. It was however, printed on a UM2 by a company called Ownage. The UM2 was given to them in collaboration with CG student awards to print the student trophy.
This was the winning entry.
Can anyone recognise that support structure? ownage typically use high end printers, so it's possible it was sliced in something else, I can't understand why they'd choose to print the base at an angle like that, unless it was to avoid internal overhangs, allowing a hollow print, also possible, that the supports are completely custom, each part has it's own flat base / riser, good idea to keep your support from breaking off the glass bed.
Woah... one day, when I grow up, I will be printing stuff like that! *dreams*
I've printed a 3d scanned Motorcycle Glove I've done a long time ago. It tool 7 hours to print at 0.1 layer height. The print speed was something around 30mm/s. I'm still amazed at how strong and light PLA prints are! I have a whole album of photos of this print.
That's an awesome print! It looks like they printed on that angle because the final sculpture's front base has so much of an overhang.
Looks great, scan looks good too, what did you use to scan it?
362
282
221
179
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
cloakfiend 282 posts
skint 221 posts
SandervG 179 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
tmrevlje 1
damn that's a nice bracelet pm_dude
