Ultimaker Community of 3D Printing Experts
Post your latest print!
IRobertI
Posted · Post your latest print!
Definitely more fun than the ice blade covers I did before :wink:
Scaled to 80%, KISSlicer, UM original, 0.1 mm layer height, 7:45 h printing time, no post-processing
This is a real top quality print! Awesome!
What material did you use? At which speed was it printed?
    I only removed 3 support structures that KISSlicer added (lower right arm, left boob and neck). I'm way too lazy and impatient for considerable post-processing ...
    I used "well-seasoned" white PLA from German RepRap at 205°C, with PLA/PHA or faberdashery the surface might even become a little smoother.
    Print speed was 40 mm/s.
    Hi Lennart ! :-)
    I used Cinema4D because I have a floating license at home for it.
    Its a very easy to use program and with a little practice you can make some nice clean printable objects.
    For this object, it was super simple. Create a profile polygone on plan, extrude up. copy original polygon shape, extrude that up with 5 layers. then Bolean the second from the first. Then pick the polygons from each layer of your second object. and using the resizer tool bring them down smaller. so you get a nice incline in the shape.
    Create a few solid boxes for your slots and group those.
    Then Bolean the grouped slots out of the main body bolean object.
    Then export as STL and your ready to print :-) :-)
    Ian :-)
    I know you guys wont believe me when I say this... but my beauty is not all natural !
    I like many need sometimes a little help ;-)
    Thanks to my ultimaker2. I can push back 10 years of aging and bad hair within an instant with my beauty ultimaker comb !
    Ian ;-) LOL
    Haha, nice pose.
    And this Ultimaker fandom corner looks pretty sharp.
    You know, when I started going bald I was a little bit sad about it. A few years later and a fair bit more hair lost, I couldn't be happier. Just cut it short and don't have to worry about silly things like keeping the hair in check :D
    @ lesvilla, did you do both of those pieces without support?
    @Simon, those test prints look great!!
    Pretty much yeah. There's some sagging, but nothing that would be alarming :p
    I like many need sometimes a little help :wink:
    Ian :wink: LOL
    Ian, you're thinking about your beauty.
    I'm already some years older than you, therefore I'm thinking about the organization of my daily body care. It was always a challenge to find the necessary parts twice a day ... but that is now much easier. Thanks to Ultimaker!!!! :-)
    20140118 122730
    respect Sigi !! very nice :-)
    Ian :-)
    you could say, ultimaker is helping beautiful people become even more beautiful ?
    Ian ;-) LOL HEHEHE
    Who has a "Hair" design to print for all of us bald guys ^^
    good question ! and even better challenge !
    but honest question for you... would you wear what I print for you ??? ;-)
    Ian LOLL
    I have always dreamed of having an Afro like the Jackson Five... it just depends on the colour you choose :)
    Maybe that'll work better with a 3Doodler ;)
    (Hope I'll get mine soon...)
    /edit
    Just to stay on-topic: my latest print:
    Gearbox 1Gearbox 2
    Nothing fancy I'm afraid, but still a big step for my UM1:
    This is the first part that I've printed more or less successfully with my new Basalt HBP.
    I printed it directly on the bed, no tape, no glue or anything. Just the bare HBP @ 52°C. The bed temperature needs to be adjusted very carefully, or the plastic either won't stick if it's too cold, or will warp right off the bed if it's too warm. I might get a problem with that when printing large parts because there's rather large temperature drift between the center and the corners of the HBP.
    The part itself is a gearbox for the needle-test-adapter I'm designing at work atm. Read gallery description if you're interested.
    This will be my trial by fire for the UM1. Need a high precision and durability in order to get this thing working...
    good solid print Johnny !.. like it ! :-)
    Ian :-)
    Day 6 with UM2:
    UM2 just finished a part with the largest plain surface for me until now.
    No problems at all.
    Layer height: 0,2
    Print speed: started with 50 mm/s and went up to 80 mm/s, the top part of the print was done with 70 mm/s
    Nozzle temp: 210 °C
    20140122 185458
    20140122 200102
    20140122 202306
    20140122 202334
    Sigi, what material? PLA? ABS?
    Great looking print Sigi! did you print it with pla? How did you change the mm/s, with the rotary encoder dial mid print?
    Sigi -fantastisch! What did you do to make it stick and not to warp?
    The print was done with PLA.
    I changed the print speed by using the Tune menu during the print (while sitting in front of the UM2 and enjoying the perfect print quality).
    I just wanted to try if there is any underextrusion happening while speeding up. But no missing Filament at all up to 80 mm/s.
    At the soaring parts of the print I manualy reduced back to 70 mm/s.
    I just used the heated bed with 75 °C. Cleaned this before the print with a soft tissue. :-) :-) However I'm sure that there is no fat on it at all.
    No glue, no hairspray, just the heated bed.
    Sigi
    I've been meaning to post this for a couple of days now - a print my 12 year old daughter did this weekend, for one of her classmates. it came out nicely with 0.15mm layers at 50mm/s. It was printed totally hollow, with 0.8mm walls, and 0.9mm top/bottom thickness - so the 'extra' infill meant that the almost-horizontal roof of the Tardis printed great.
    Tardis
    Of most note, I suggested she try the 'Cool Head Lift' feature, and it worked really well on the light on top. Great detail, and no re-melting. For scale, the light is 11mm high; the spike on top is 1.5mm high.
    Tardis Detail
    The plastic is Faberdashery Galaxy Blue (which has silver flecks in it), and the http://www.thingiverse.com/thing:131701is from Thingiverse.
    I've been trying to replicate a Module 1.0 15mx15m rack, since they aren't available here in the USA (and wow, shipping from the UK for a $9 part!)
    Ultimaker Original, PLA, 220C and speed of 40. I wish the rack edges came out better.
    Ian :wink: LOL
    Heh,
    Strike a pose!
    Actually, now that you can create your own comb, you could make it fit your own head;)
    Round comb.. It should not become any crazier!
    The plastic is Faberdashery Galaxy Blue (which has silver flecks in it), and the original model is from Thingiverse.
    It looks like a model made with a DLP blue resin printer!
    Very nice!
    I think I'm going to do another try at something i wanted to do before: model/simulating water bouncing of an object and capturing it for 3d printing. Maybe blender can do that, any other ideas?
    EDIT:this is not as easy as I thougth. I can make a brick explode, but I cannot make a fluid..hmm
    Cheers!
    Lennart
     Share
      • New here? Get ahead with a free onboarding course
        • 11 replies
