Did my first painting. I used a little airbrush set for this.
Also did a print of the Winged Victory, its about 40 cm high. Its slightly primed and spray painted.
My latest print is a wooden mask (Model by Michalis on BlenderArtists [1])
Hi Conz,
woow! This is one of the best work I've seen with woodFill, looks very nice. Good to hear that you were able to overcome some issues and kept trying. The final model looks very cool, we shared your 3d print project with our twitter follower, I'm sure they'll love it
woow! This is one of the best work I've seen with woodFill, looks very nice. ... The final model looks very cool, we shared your 3d print project with our twitter follower, I'm sure they'll love it
Thank you! Will retweet it.
Wow that winged angel thing looks really great!
As does the demon thing, pretty awesome first painting!
That is some top notch painting right there... man... I gotta get me an airbrush set..
How hard are these to use/learn?
I used to do model painting in my younger years (warhammer fantasy) using fine brushes, so have some idea of highlighting, shadowing, blending etc., but have never used an airbrush or even seen someone use one...
Hey guys. So here it is, my first ever 3D printed design. As I said before I was having issues with Cura and had to print this guy a lot smaller than I had intended so a lot of the detail is lost due to scale. I also made the mistake of modeling some parts too thin, you can see that the bottom row of teeth didn't print properly. Other than that I'm pretty pleased with the results.
Height 100mm
Print speed 30mm/sec
Layer height 0.06mm
Bed temp 65C
Nozzle temp 210C
Time 12.5 hrs
Pictures where taken on my iphone so the quality is not great. There seems to be a lot of noise on the print so I think I still have a bit of tweaking to do. I managed to solve the issue that I was having with Cura freezing the progress bar on large prints by rolling Cura back to 14.01 as per braddock's suggestion. I'm now printing another model at 150mm and 59 hrs :shock: lol. so far its looking good and there doesn't seem to be as much noise, maybe this is something to do with using the earlier version of Cura.
Nice. To get rid of the whitish surface (sanding on 4th picture), you can wash him with warm/hot water (not to hot). And rub with your finger the surface. It will help a little bit.
Nothing impressive but thought i would post it anyway..
Ultimaker robot printed in ninja flex using iroberti feeder system on UM2
Looks good! Yeah, I noticed weird stuff in the latest cura when I installed it, so just kept using 14.01
I think there's another version out now though?
Height 100mm
Layer height 0.06mm
Bed temp 65C
Nozzle temp 210C
Time 12.5 hrs
A little timelapse of the celtic skull i printed friday. Will post pictures when i'll upload them
Layer height: 0.16mm
Colorfabb black
Print time: 12h
simple but very cool !
Ian :-)
"Sometimes I lack inspiration, anybody knows a good source for inspiration? "
love the egg holders, i get most of my inspiration when i am outside in the woods walking around
this was my biggest print so far, printed in two parts simultaneously on two UM1s. it stands 50cm tall (base 10cm, pug 30cm, crown 10cm)
The paintjob was kind of unintentional (the color was dried and my airbrush died, long story) buit i like how it turned out in the light
Thank you! All credits should go to the awesome person who uploaded this beauty http://www.thingiverse.com/thing:196038
Thank you!
My only experience with painting models also base on Warhammer 40k! So you got a pretty good start i guess
Using the airbrush is not that hard. But make it work is . I used acryl colors (out of a tube) and thinned them with water. Its pretty hard do make it spray smooth without drops. Also always start with the brightes color, i sprayed the red like 5-6 times but it just stayes that dark (i wanted it to be a bloody red). For the effekt i just never sprayed right on to the model, i just tried to keep a good angle so the red doesn't spray in the "deeper" spots. Afterwards i did realize i should have painted the deeper areas first fit black, and leave the higher sports white (filler), then i would have had a nice bloody red. You can spray a 2-3mm fine circle, witch make it pretty easy to do color fadings (like on the horn).
But overall a cheap airbrush set is really fun to work with
OOw the pug is nice! are you willing to share your model? My brother is into pugs, but i have not found a decent enough model end my skills are not yet good enough for a detailed model.
With which material was it printed?
Cheers!
Yet another skull:
Very happy with this one. Probably my best print yet :ugeek:
My son wanted a glow in the dark dragon
Valcrow, do you have any source on how to paint the Mech you made so darn beautifully?
Thanks! and yes, I was following along this tutorial more or less:
I'm still learning and trying stuff, this one seemed to work out pretty well! but beware.. huge mess. Salt + airbrush = salt everywhere.
I finally got my ass around to trying out some flexible filament. I started with something easy, like the treefrog I had a couple of bad starts as it refused to stick to the bed so I put down some kapton which seemed to solve the issue. I'd say the print was quite uneventful (which is good), retractions seemed to work just fine and I had no problems with filament transport. This stuff seems to absolutely hate overhangs though, they look terrible. but other than that I'd say that I'm pretty happy with my first flexy print. This was printed with my new feeder.
Those paying attention will notice the bad leveling. I flipped the glass plate and put on the tape so it really should've been re-leveled before printing but I couldn't be arsed to do it. I manually pushed down on the bed occasionally to relieve pressure during the first layer.
This is for Makingzone & Skint.
Sorry it took so long to get these files up. I redesigned the base and I am making a few more mods for the gears.
The Dremel Workstation is now on Youmagine! https://www.youmagine.com/designs/dremel-workstation-press
Aside from the top of the body being chopped off and printing a separate part, the body printed really well.
I've had a number of 24 hour + prints going lately, and the UM2 has been printing very well, no under extrusion etc.
Wow, braddock!
Amazing piece.
thanks mate, btw, my overhangs have improved a lot printing with colorfabb at 210 degrees and fans on full after 0.5mm or first layer.
Wow, braddock!
Amazing piece.
You're welcome, pal, it's great because you have amazing sculpts wonderfully printed.
Means a lot in terms of inspiration/motivation.
Thanks for the hint!
As soon as I'll be back from a small tour in Switzerland, I'll try my brand new (delivered today) unopened Colorfabb filament with these settings.
I did a couple of tests today, on a small hand, with the usual Ultimaker blue PLA and it came out kinda like "no.hope.".
I also tried to put the overhang supports from 45° instead of the default 60° but it didn't change that much.
Top Posters In This Topic
362
179
221
280
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
SandervG 179 posts
skint 221 posts
cloakfiend 280 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
brumbaer 0
That wooden mask is awesome.
