Hey Didier, nice cam holder. But I have to ask - doesn't it shake too much while printing? Does it impar image/video quality?
I caught this video of the software you were using Jonathan Gueron, that's some pretty cool stuff: https://www.youtube.com/watch?v=DzCeHFEUaro, also nice application or the software.
That's a huge haul Leo! You'll have to tell us what you think about that pen, do you think it could be used to fuse prints together?
@Valcrow and IRobertI, yeah I'm probably just jealous of the artistic capacities all of these Ultimaker people have...who am I kidding I would probably just sculpt naked ladies if I could do what those guys are doing :mrgreen:.
@Didier Klein nice prints, they look very professional. That skull looks really slick, lots of detail and very shiny. Nice camera setup, I've been wanting to set something up on my rig as well. Did you use a raspberry pi camera to get higher frame-rates for online video streaming? If so are you pleased with the quality?
I used it to do the timelapse video of the vase linked above. Hard to tell if it has moved but i don't think so. I guess it shakes a bit when the head shakes the whole printer. I can try and record a video where it shakes to see how it goes if you want
The parts can be found on thingiverse (case and cam holder) i just added two small legs to snap it on the printer and one thing to mount the camera mount to the case. If someone is interested i can upload them to youmagine.
Thanks Aaron the skull is very nice yes, the model itself is very detailed it helps a lot. it was printed at 0.16mm layer height but looks very smooth.
The cam is a raspicam but for the moment i don't know why but if i try to stream the video and check it out on my laptop i loose the wifi connection. Quality looks good to me. It's able to take very good quality pictures too.
hey guys...
never posted something here but i always love the stuff you make.
my latest project is a controlpanel because i didn't like the original.
wanted something with silver and wood and here it is. a little big but i wanted it like that:)
the switches are there to turn on the light and the heated bed. there are also hidden LED's above the switches that light through the front. i made a design that i can easily switch between masks with different colors.
next step is to install all the electric components and then i'm done;)
That looks great! love the knob shape and duotone.
Looks like you're pretty serious about your mods too, you should definitely post more stuff.
hey guys...
PIMP that thing baby !!
Absolutyl love your new control pad !! very retro and very cool !!
Ian :-)
Awesome work ulbie
So I've been testing out the free colorfabb samples I've been given and I have to say That I'm a bit disappointed so far. I've tried various different heat and speed settings but everything I try with this stuff comes out very stringy/hairy.
Printed a small version of the grinner character
Height 50mm
Speed 30mm/sec
infill speed 50mm/sec
layer height 0.02mm
nozle temp 200C
bed temp 60C
I really hope its just a bad sample and that the bluegrey colorfabb that I bought isn't like this
Does anyone else out there that uses colorfabb have any tips or advice on heat settings etc?
@LeoDDC: colorFabb has a new "learning" section on their site. There are a few sample objects with print settings:
But layer height of 0.02? Isn't it a bit extreme? I haven't printed below 0.05, but when I did, I remember the prints to be very "hairy" - lots of very thin strands even on flat surfaces.
Also the Cura tooltip for infill speed (advanced settings) indicates that it can impair print quality if set differently from the overall speed. Another thing to try.
Thanks for the link.
I only went down that far just to see how it came out but on other test prints I have done with 0.06/ 0.1 and 0 infill speed I still had crappy results. I remain positive as I have seen some really nice prints done in colorfabb so I'm sure its just a learning curve.
I hope so too. Never printed with colorFabb but I can't wait to fix my printer issues since I have a very sexy http://colorfabb.com/fluorescent-green spool here to play with
Hey Leo, I've been getting good results with colorfabb at 210 with very little stringing, but my best results are with larger prints.
On the UM2 there's very little noticeable difference between 0.06 and 0.04 other than waiting a lot longer.
0.02 is a waste of time.
Small detailed parts with overhangs don't go too well with FDM printers, but you can get much better results than what you have here.
Make sure your wall thickness is no less than 1.2mm
In expert settings, set both the retraction options to 0 (min travel and min extrusion)
On the printer, set retraction length to 5.5, these tweaks should reduce your stringing.
I thought some of you might like to see this. Jamie from 3Dprintergear here in Aus printed my Ieyo character on a Form1 and sent me the print. I'm not sure if he used it's highest settings, it looks to me to be a 50 micron print.
You can still see layer lines, but the surface is beautiful, especially the overhangs, just nice smooth surfaces. Difficult to photograph this material with my phone, but you can tell it's smooth. This process is simply better for this kind of work, the surface quality and overhangs, can't be matched with FDM.
When I saw this, part of me had one of those "I bought the wrong printer" moments... but, this apparently used $25 worth of resin, and it's quite brittle, the tip actually broke off.
I also wouldn't want to use this type of printer for my larger scale stuff... like the 1:1 terminator Endoskull I'm making.
@braddock: Thanks for the info man, I'll give this a try soon.
The form 1 print looks really nice but I have heard that there are still a lot of teething issues with this printer so don't be too hung up. Also when the dual extruder comes out we will be able to print solid beds of dissolvable supports and have perfect overhangs... I hope :grin:
I was really considering the form 1 back when deciding which printer to buy as well.. but the cost of the resin was the biggest turn off.
Anyways, latest print/paintjob.. A lightsaber for may the 4th be with you day. :mrgreen:
Printed at 0.12mm 0.2mm for the rifle grenade.
Bonus mini one!
More pics here:
http://www.redicubricks.com/3d-printed-full-sized-obi-wan-lightsaber/
And STLs here:
https://www.youmagine.com/designs/star-wars-lightsaber
Ok Valcrow, you convinced me with that beautiful thing...next time to carnival I will dress myself as a jedi:) Whenever I see a cheap plastic replica in a shop I will laugh by knowing I have the better one...just need to get some painting skills;)
Great job!
Woah Valcrow that is Awesome work. Loving that paint job dude.
I think Valcrow is not telling the truth. This is not a 3D print. It's a real working lightsaber and Valcrow built it himself as he is actually a Jedi. At least the lightsaber looks like that.
There is nothing more to say than that: Awsome print and paint job! :cool:
The Force was definitively with you when you built that!
As usual many superior prints/paint jobs; nice looking paint job Valcrow. @Braddock, thanks for the post. I've been wondering about the print material for a while; I knew it was expensive and I heard it was brittle which are the two reasons I did not go that route either. I'm hoping water soluble support material along with a second extruder will brighten up ugly overhangs.
I spent an afternoon designing and building this little guy; it's a key-ring flashlight. I wanted to build something really small that had no other pieces other than leds (surface mount), wire, and a battery. For the switching mechanism, you push the battery towards the led side of the device, there are little notches that hold the battery in place and keep the battery from falling out the back of the device. The battery can be removed if enough force is exerted to push it pas the notches at the back.
This is sort of the evolution of the light, initially it was just to test an idea I had to embed circuitry into the plastic via channels for wires and such. It ended up working and led to the LED flashlight. The solder job is significantly better than what is depicted below, all the functional units are glued together. If anyone is interested I can take a really good picture of one before it gets sealed, I'm currently printing out a whole tray of them.
I think the coolest part is the switching mechanism. The battery touches wire that I've melted into the plastic itself, I take a pair of tweezers and bend a really small hook into the wire end, then rest it upon little plastic islands I printed out to retain the metal, and touch the tip of my iron to the top of the hook which supplies heat to the bottom of the hook which resides on the plastic island. The heat melts the plastic and I push down just a little with the iron to seat everything; the bond is really strong and I have yet to break the switching mechanism through lots and lots of fiddling.
Very clever Aaron! It looks very nice (want!)
Now combine it with a smaller third plate where only the circuitry+battery resides, use the pause_at_z plugin to place the plate on the already printed one, continue the print and you'd have a seamless object
I was working on something practical the last days. An Inbus holder that lets you rotate the inbus keys so you can get the smaller ones out easier... i needed a whole battery of gears to get it so that ,if you rotate one inbus, all rotate.
Thanks all for the kudos.
@dim3ntioneer - I think I would be ejected from being a jedi for neglecting my lightsaber to that level of rustyness. :oops:
@Aaron - that's a clever solve! Love seeing stuff that's well designed for function... Just makes you appreciate all the little things.
@takei that's cool! does it rotate smoothly?
Top Posters In This Topic
362
282
221
179
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
cloakfiend 282 posts
skint 221 posts
SandervG 179 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
DidierKlein 729
A couple pics of my latest prints
The celtic skull that i posted the timelapse a while ago:
A double twisted vase:
The timelapse (yes i love timelapses :mrgreen: )
A raspberry pi case with camera and mount for the um2:
