my latest creation....
Cool, you made a device that grinds up the filament for recycling?
Then you need this one:
Which I think is awesome and very scary at the same time.
That's a lot of compression on your filament Ian. Checked for a plug already?
Or you can check out
http://betterfuturefactory.com/
They already went to Lowlands (Big Dutch Festival) to recycle the used plastic cups and recycle them
to rings and what not.
Ultimakers have been used for printing the recycled plastic, awesome!
They have other big events in there agenda.
another of my modern art creations today with my new ultimaker....
who needs straight lines and quality, when you can create automatica modern art !
you're really getting the hang of failure as a form of art here Ian
I printed this yesterday:
http://www.thingiverse.com/thing:30323
For the first time, absolutely no adjustments! I just hit the print button and scraped the finished product off my cooled-down bed four hours later!
Sorry for the poor quality of the photo, my camera is having trouble focusing on this object, no doubt as a result of its color.
help me out here, coral, cauliflower, or cat brains mashup?
lol! It's actually a crystal structure of the catalytic core of pyruvate dehydrogenase from Azotobacter vineladii, see here
http://www.rcsb.org/pdb/101/motm.do?momID=153
OK, we're sorry we asked
looks good tho, cat brain was my vote btw
Ok here's another Pyruvate Dehydrogenase! This one is closer to what humans have.
10 hour print! Support removal took way too long on this.
I've done that too, and I invented fluff and string
but I have to say that's an awesome photo for marketing purposes - just needs a catchy slogan now
very nice ! are you using solidworks for your modelling ?
have you uploaded that to thingiverse ?
Ian
ok here is something i cooked up for a friend a few weeks ago.
sadly the man had the 3d model created in archicad and every time we tried to export the model, the beautiful soft curved and profiles came out over simplified and blockage but i had zero time to make a new model and for my friend, it was really not needed to be perfect....
any way excuses over, here are the photos...
Yep, that's SolidWorks. And no I haven't uploaded it since it's so specific to my (homebuilt) desk so I doubt it'd fit anything else really
Doesn't matter, someone might find a use for it, or use it as inspiration for their own variation. Soildworks should be able to export .step or .iges files, which makes it possible for other people to modify your design quite easy.
I see a lot of people using solidworks - but isn't it ultra-expensive? do they have a free version available or something?
solidworks is seriusly good for making real life 3d objects.
and yes for the fill edition, it costs a lot of money but if you want to bounce a round some easy ideas with the free trial version or if your a student, then you can get a free student license which is really good.
im not so sure, so many people are getting hacked versions any more off the net ?
from my experience, there are just too many nasty little trogans, viruses, back doors and zoombies built into these cracked illegal copies on the net, that it is simply not worth going down the dark path again.
Ian
I hate to drift off-topic here, but I just wanted to mention that another alternative that I've not seen discussed before is Bricscad. It's expensive, but not nearly as expensive as Solid Works. I've used it for 2d lasercutting and quite like it for that. Havn't tried it for 3d yet, but it looks promising on the surface. I'm just evaluating the trial version right now, but am seriously considering buying the Pro version or trying to contact the company to negotiate a hobbyist license.
Cheers,
Troy.
any new models guys ??
Ian
I haven't printed it yet, but I've designed a single wall flexible gear today.
Photo also shows some combing problems, and my new 3D window colors :-)
Top Posters In This Topic
362
275
221
177
Popular Days
Jan 5
30
May 12
26
Jan 13
23
May 1
22
ian 362 posts
cloakfiend 275 posts
skint 221 posts
SandervG 177 posts
Popular Days
Jan 5 2014
May 12 2014
Jan 13 2014
May 1 2014
Popular Posts
kmanstudios
Took me forever to do this. And it is still rougher than I would have liked. 3D concept rendering: Finished piece:
kmanstudios
I just finished this. It was a multi-part print for ease of painting. Some of it I am not sure what happened...but hey, it is purty....And, I am unanimous in that ? Test Render Parts
gr5
Bath interferometers. I have made about 20 of these for people who use them to test their telescope mirrors. They are amazingly accurate and can do better than a $40,000 Zygo PSI optical tester. Th
Posted Images
alaris2 1
totally agree with the last 3 points -
as far as the recovery bit goes - if you're using k'slicer, set the prime value after retraction to very slightly less than the retract value and see if it still gives problems. there is sometimes a slight asymmetry caused by molten plastic seeping back down into the nozzle. i suspect the problem is path length dependent too but no slicers take that into account as far as i'm aware.
